Issue with File masking on Date/Time stamp files being pulled down - FTPS
When executing an SQR program in Oracle - trying to get a file that has a date/time in the file name and using the * and or ? (wildcard) values - the process doesn't find the file. If I physically hard code the full file name with date/time the download works fine. We are using 5.9.2 version of software. Any assistance would be appreciated.
Re: Issue with File masking on Date/Time stamp files being pulled down - FTPS
