Scripting zOS session fails - psFTP works
Script fails after Login on changing directory to HOME, here is LOG and Script
param (
[string]$text1 = "0",
[string]$SRC = "PROD",
[string]$text2 = "0",
[string]$TGT = "DEV"
##write-output $diaglevel
##write-output $bundleid
try
# Load WinSCP .NET assembly
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
# Set up session options
HostName = ""
PortNumber = 22
UserName = "3"
Password = "7"
SshHostKeyFingerprint = "ssh-rsa 1024 6d:19:01:b0:27:36:ff:12:f2:a1:1c:21:5e:cb:77:d8"
#FtpSecure = [WinSCP.FtpSecure]::Implicit
#FtpSecure = [WinSCP.FtpSecure]::Explicit
try
$TDMROOT = "C:\tdm"
$LogPath = $TDMROOT + "\logs"
$JCLPath = $TDMROOT + "\jcl"
$Template = $JCLPath + "\iebgener.jcl.txt"
$rand = Get-Random -minimum 1 -maximum 100
$Job = $Template + "." + $rand + ".txt"
$session.SessionLogPath = $LogPath + "\subJCLFTP.log"
# Connect
# Your code
Write-Host ("Opening..")
$transferOptions.TransferMode = [WinSCP.TransferMode]::Ascii
$content = [System.IO.File]::ReadAllText($Template).Replace("<SRC>",$SRC)
$content = $content.Replace("<TGT>", $TGT)
[System.IO.File]::WriteAllText($Job, $content)
#Write-Host ("Auth..")
#$session.ExecuteCommand("AUTH SSL 1").Check()
Write-Host ("JES..")
# $session.ExecuteCommand("SITE FILETYPE=JES").Check()
$session.ExecuteCommand("cd //-JES.intrdr").Check() ##########
Write-Host ("Put..")
$transferResult = $session.PutFiles($Job, "~", $False, $transferOptions)
Write-Host "END..Result "
# Your code END
finally
$session.Dispose()
exit 0
catch [Exception]
Write-Host ("Error {0}" -f $_.Exception.Message)
:evil:
CONSOLE
PS C:\Windows\system32> C:\Users\c653\Downloads\debugFTP.ps1
Opening..
JES..
Error Error changing directory to '//C653'.
Command 'cd "//C6053"'
failed with return code 1 and error message
cd: //C6053: EDC5129I No such file or directory..
LOG
. 2017-05-23 18:56:05.773 --------------------------------------------------------------------------
. 2017-05-23 18:56:05.774 WinSCP Version 5.9.5 (Build 7441) (OS 6.3.9600 - Windows Server 2012 R2 Standard)
. 2017-05-23 18:56:05.774 Configuration: nul
. 2017-05-23 18:56:05.774 Log level: Normal
. 2017-05-23 18:56:05.774 Local account: USAGNT\xxxxxx
. 2017-05-23 18:56:05.774 Working directory: C:\Program Files (x86)\WinSCP
. 2017-05-23 18:56:05.774 Process ID: 7972
. 2017-05-23 18:56:05.775 Command-line: "C:\Program Files (x86)\WinSCP\winscp.exe" /xmllog="C:\Users\xxxxxx\AppData\Local\Temp\wscp2A9C.026E04AB.tmp" /xmlgroups /xmllogrequired /nointeractiveinput /dotnet=595 /ini=nul /log="C:\tdm\logs\subJCLFTP.log" /console /consoleinstance=_10908_22467095_529
. 2017-05-23 18:56:05.775 Time zone: Current: GMT-4, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/12/2017, DST End: 11/5/2017
. 2017-05-23 18:56:05.775 Login time: Tuesday, May 23, 2017 6:56:05 PM
. 2017-05-23 18:56:05.775 --------------------------------------------------------------------------
. 2017-05-23 18:56:05.775 Script: Retrospectively logging previous script records:
> 2017-05-23 18:56:05.775 Script: option batch on
< 2017-05-23 18:56:05.775 Script: batch on
< 2017-05-23 18:56:05.775 Script: reconnecttime 120
> 2017-05-23 18:56:05.775 Script: option confirm off
< 2017-05-23 18:56:05.775 Script: confirm off
> 2017-05-23 18:56:05.775 Script: option reconnecttime 120
> 2017-05-23 18:56:05.775 Script: open sftp://xxxxxx:***@xxxxxx:22 -hostkey="ssh-rsa 1024 6d:19:01xxxxxx7:d8" -timeout=15
. 2017-05-23 18:56:05.775 Session name: xxxxxx@xxxxxx (Ad-Hoc site)
. 2017-05-23 18:56:05.775 Host name: xxxxxx (Port: 22)
. 2017-05-23 18:56:05.775 User name: xxxxxx (Password: Yes, Key file: No, Passphrase: No)
. 2017-05-23 18:56:05.775 Tunnel: No
. 2017-05-23 18:56:05.775 Transfer Protocol: SFTP
. 2017-05-23 18:56:05.775 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2017-05-23 18:56:05.775 Disable Nagle: No
. 2017-05-23 18:56:05.775 Proxy: None
. 2017-05-23 18:56:05.775 Send buffer: 262144
. 2017-05-23 18:56:05.775 SSH protocol version: 2; Compression: No
. 2017-05-23 18:56:05.775 Bypass authentication: No
. 2017-05-23 18:56:05.775 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2017-05-23 18:56:05.775 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2017-05-23 18:56:05.775 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2017-05-23 18:56:05.776 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2017-05-23 18:56:05.776 Simple channel: Yes
. 2017-05-23 18:56:05.776 Return code variable: Autodetect; Lookup user groups: Auto
. 2017-05-23 18:56:05.776 Shell: default
. 2017-05-23 18:56:05.776 EOL: LF, UTF: Auto
. 2017-05-23 18:56:05.776 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2017-05-23 18:56:05.776 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2017-05-23 18:56:05.776 SFTP Bugs: Auto,Auto
. 2017-05-23 18:56:05.776 SFTP Server: default
. 2017-05-23 18:56:05.776 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2017-05-23 18:56:05.776 Cache directory changes: Yes, Permanent: Yes
. 2017-05-23 18:56:05.776 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2017-05-23 18:56:05.776 DST mode: Unix
. 2017-05-23 18:56:05.776 --------------------------------------------------------------------------
. 2017-05-23 18:56:05.776 Looking up host "xxxxxx" for SSH connection
. 2017-05-23 18:56:05.776 Connecting to xxxxxx port 22
. 2017-05-23 18:56:05.778 We claim version: SSH-2.0-WinSCP_release_5.9.5
. 2017-05-23 18:56:05.864 Server version: SSH-2.0-OpenSSH_6.4
. 2017-05-23 18:56:05.865 We believe remote version has SSH-2 channel request bug
. 2017-05-23 18:56:05.865 Using SSH protocol version 2
. 2017-05-23 18:56:05.865 Have a known host key of type rsa2
. 2017-05-23 18:56:05.879 Doing ECDH key exchange with curve nistp256 and hash SHA-256
. 2017-05-23 18:56:05.952 Server also has ssh-dss host key, but we don't know it
. 2017-05-23 18:56:05.953 Host key fingerprint is:
. 2017-05-23 18:56:05.953 ssh-rsa 1024 6d:19:01xxxxxx7:d8
. 2017-05-23 18:56:05.953 Verifying host key rsa2 0x23,0xbb6bxxxxxxf5279f1705c64 5e5a5222dfb57dab 0e0e5857cf0b144b 5f22bafab67358d0 63f07c3d2751541f cd7ff7230ce4050a 0008a872aa5a1c80 4c5ce0e01040be54 98971c91bbab10fb 7626f662c7106c62 6ecbc8e4eb790338 7f8136544edf27e7 with fingerprint ssh-rsa 1024 6d:19:01xxxxxx7:d8
. 2017-05-23 18:56:05.953 Host key matches configured key
. 2017-05-23 18:56:05.954 Initialised AES-256 SDCTR client->server encryption
. 2017-05-23 18:56:05.954 Initialised HMAC-SHA-256 client->server MAC algorithm
. 2017-05-23 18:56:05.954 Initialised AES-256 SDCTR server->client encryption
. 2017-05-23 18:56:05.954 Initialised HMAC-SHA-256 server->client MAC algorithm
! 2017-05-23 18:56:06.194 Using username "xxxxxx".
. 2017-05-23 18:56:06.215 Server offered these authentication methods: publickey,password
. 2017-05-23 18:56:06.215 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2017-05-23 18:56:06.215 Using stored password.
. 2017-05-23 18:56:06.216 Sent password
. 2017-05-23 18:56:06.265 Access granted
. 2017-05-23 18:56:06.265 Opening session as main channel
. 2017-05-23 18:56:06.291 Opened main channel
. 2017-05-23 18:56:06.501 Started a shell/command
. 2017-05-23 18:56:06.501 --------------------------------------------------------------------------
. 2017-05-23 18:56:06.501 Using SFTP protocol.
. 2017-05-23 18:56:06.501 Doing startup conversation with host.
> 2017-05-23 18:56:06.501 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2017-05-23 18:56:06.790 Type: SSH_FXP_VERSION, Size: 155, Number: -1
. 2017-05-23 18:56:06.790 SFTP version 3 negotiated.
. 2017-05-23 18:56:06.791 Unknown server extension posix-rename@openssh.com="1"
. 2017-05-23 18:56:06.791 Unknown server extension coz-zopts@dovetail.com="0"
. 2017-05-23 18:56:06.791 Supports statvfs@openssh.com extension version "2"
. 2017-05-23 18:56:06.791 Unknown server extension fstatvfs@openssh.com="2"
. 2017-05-23 18:56:06.791 Supports hardlink@openssh.com extension version "1"
. 2017-05-23 18:56:06.791 We believe the server has signed timestamps bug
. 2017-05-23 18:56:06.791 We will use UTF-8 strings until server sends an invalid UTF-8 string as with SFTP version 3 and older UTF-8 strings are not mandatory
. 2017-05-23 18:56:06.791 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2017-05-23 18:56:06.791 Getting current directory name.
. 2017-05-23 18:56:06.791 Getting real path for '.'
> 2017-05-23 18:56:06.791 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2017-05-23 18:56:06.794 Type: SSH_FXP_NAME, Size: 37, Number: 16
. 2017-05-23 18:56:06.794 Real path is '//xxxxxx'
. 2017-05-23 18:56:06.794 Startup conversation with host finished.
< 2017-05-23 18:56:06.794 Script: Active session: [1] xxxxxx@xxxxxx
> 2017-05-23 18:56:07.386 Script: pwd
< 2017-05-23 18:56:07.386 Script: //xxxxxx
> 2017-05-23 18:56:07.485 Script: call cd //-JES.intrdr
< 2017-05-23 18:56:07.485 Script: Searching for host...
. 2017-05-23 18:56:07.486 [Shell] Looking up host "xxxxxx" for SSH connection
. 2017-05-23 18:56:07.486 [Shell] Connecting to xxxxxx port 22
. 2017-05-23 18:56:07.486 [Shell] We claim version: SSH-2.0-WinSCP_release_5.9.5
< 2017-05-23 18:56:07.486 Script: Connecting to host...
. 2017-05-23 18:56:07.573 [Shell] Server version: SSH-2.0-OpenSSH_6.4
. 2017-05-23 18:56:07.574 [Shell] We believe remote version has SSH-2 channel request bug
. 2017-05-23 18:56:07.574 [Shell] Using SSH protocol version 2
. 2017-05-23 18:56:07.574 [Shell] Have a known host key of type rsa2
. 2017-05-23 18:56:07.586 [Shell] Doing ECDH key exchange with curve nistp256 and hash SHA-256
. 2017-05-23 18:56:07.663 [Shell] Server also has ssh-dss host key, but we don't know it
. 2017-05-23 18:56:07.663 [Shell] Host key fingerprint is:
. 2017-05-23 18:56:07.663 [Shell] ssh-rsa 1024 6d:19:01xxxxxx7:d8
. 2017-05-23 18:56:07.663 [Shell] Verifying host key rsa2 0x23,0xbb6bxxxxxxf5279f1705c64 5e5a5222dfb57dab 0e0e5857cf0b144b 5f22bafab67358d0 63f07c3d2751541f cd7ff7230ce4050a 0008a872aa5a1c80 4c5ce0e01040be54 98971c91bbab10fb 7626f662c7106c62 6ecbc8e4eb790338 7f8136544edf27e7 with fingerprint ssh-rsa 1024 6d:19:01xxxxxx7:d8
< 2017-05-23 18:56:07.663 Script: Authenticating...
. 2017-05-23 18:56:07.664 [Shell] Host key matches configured key
. 2017-05-23 18:56:07.665 [Shell] Initialised AES-256 SDCTR client->server encryption
. 2017-05-23 18:56:07.665 [Shell] Initialised HMAC-SHA-256 client->server MAC algorithm
. 2017-05-23 18:56:07.665 [Shell] Initialised AES-256 SDCTR server->client encryption
. 2017-05-23 18:56:07.665 [Shell] Initialised HMAC-SHA-256 server->client MAC algorithm
! 2017-05-23 18:56:07.897 [Shell] Using username "xxxxxx".
< 2017-05-23 18:56:07.897 Script: Using username "xxxxxx".
. 2017-05-23 18:56:07.916 [Shell] Server offered these authentication methods: publickey,password
. 2017-05-23 18:56:07.916 [Shell] Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2017-05-23 18:56:07.916 [Shell] Using stored password.
< 2017-05-23 18:56:07.916 Script: Authenticating with pre-entered password.
. 2017-05-23 18:56:07.916 [Shell] Sent password
. 2017-05-23 18:56:07.965 [Shell] Access granted
. 2017-05-23 18:56:07.965 [Shell] Opening session as main channel
. 2017-05-23 18:56:07.985 [Shell] Opened main channel
. 2017-05-23 18:56:08.202 [Shell] Started a shell/command
< 2017-05-23 18:56:08.202 Script: Authenticated.
. 2017-05-23 18:56:08.203 [Shell] --------------------------------------------------------------------------
. 2017-05-23 18:56:08.203 [Shell] Using SCP protocol.
. 2017-05-23 18:56:08.203 [Shell] Doing startup conversation with host.
< 2017-05-23 18:56:08.203 Script: Starting the session...
. 2017-05-23 18:56:08.203 [Shell] Skipping host startup message (if any).
> 2017-05-23 18:56:08.203 [Shell] echo "WinSCP: this is end-of-file:0"
< 2017-05-23 18:56:08.252 [Shell] SH running in non terminal environment - Defaults are:
< 2017-05-23 18:56:08.252 [Shell] *************************************************************************
< 2017-05-23 18:56:08.252 [Shell] PATH=/usr/lpp/java/J8.0/bin:/usr/lpp/tcpip/sbin:/usr/lpp/Printsrv/bin:/usr/lpp/slma/bin:/usr/lpp/NFS:/usr/lpp/zosmf/V2R1/bin:/bin:/usr/sbin:.
< 2017-05-23 18:56:08.252 [Shell] CLASSPATH=.:/usr/lpp/cicsts/cicsts52/lib/*.jar:/usr/lpp/mqm/V7R1M0/java/lib/com.ibm.mq.jar
< 2017-05-23 18:56:08.253 [Shell] LIBPATH=/usr/lpp/java/J8.0/lib:/lib:/usr/lib:/usr/lpp/Printsrv/lib
< 2017-05-23 18:56:08.253 [Shell] *************************************************************************
< 2017-05-23 18:56:08.253 [Shell] LOGNAME=xxxxxx
< 2017-05-23 18:56:08.253 [Shell] WinSCP: this is end-of-file:0
. 2017-05-23 18:56:08.253 [Shell] Detecting variable containing return code of last command.
. 2017-05-23 18:56:08.253 [Shell] Trying "$status".
> 2017-05-23 18:56:08.253 [Shell] echo "$status" ; echo "WinSCP: this is end-of-file:0"
< 2017-05-23 18:56:08.254 [Shell] WinSCP: this is end-of-file:0
. 2017-05-23 18:56:08.254 [Shell] The response is not numerical exit code
. 2017-05-23 18:56:08.254 [Shell] Trying "$?".
> 2017-05-23 18:56:08.254 [Shell] echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 2017-05-23 18:56:08.255 [Shell] 0
< 2017-05-23 18:56:08.255 [Shell] WinSCP: this is end-of-file:0
. 2017-05-23 18:56:08.255 [Shell] Return code variable "$?" selected.
> 2017-05-23 18:56:08.255 [Shell] printenv LANG ; echo "WinSCP: this is end-of-file:$?"
< 2017-05-23 18:56:08.258 [Shell] C
< 2017-05-23 18:56:08.258 [Shell] WinSCP: this is end-of-file:1
. 2017-05-23 18:56:08.258 [Shell] We will not use UTF-8
. 2017-05-23 18:56:08.258 [Shell] Changing directory to "//xxxxxx".
> 2017-05-23 18:56:08.258 [Shell] cd "//xxxxxx" ; echo "WinSCP: this is end-of-file:$?"
! 2017-05-23 18:56:08.259 [Shell] cd: //xxxxxx: EDC5129I No such file or directory.
< 2017-05-23 18:56:08.259 [Shell] WinSCP: this is end-of-file:1
* 2017-05-23 18:56:08.259 [Shell] (ECommand) Error changing directory to '//xxxxxx'.
* 2017-05-23 18:56:08.259 [Shell] Command 'cd "//xxxxxx"'
* 2017-05-23 18:56:08.259 [Shell] failed with return code 1 and error message
* 2017-05-23 18:56:08.259 [Shell] cd: //xxxxxx: EDC5129I No such file or directory..
< 2017-05-23 18:56:08.259 Script: Error changing directory to '//xxxxxx'.
< 2017-05-23 18:56:08.259 Command 'cd "//xxxxxx"'
< 2017-05-23 18:56:08.259 failed with return code 1 and error message
< 2017-05-23 18:56:08.259 cd: //xxxxxx: EDC5129I No such file or directory..
. 2017-05-23 18:56:08.260 [Shell] Getting current directory name.
> 2017-05-23 18:56:08.260 [Shell] pwd ; echo "WinSCP: this is end-of-file:$?"
< 2017-05-23 18:56:08.261 [Shell] /u/xxxxxx
< 2017-05-23 18:56:08.262 [Shell] WinSCP: this is end-of-file:0
. 2017-05-23 18:56:08.262 [Shell] Startup conversation with host finished.
< 2017-05-23 18:56:08.262 Script: Session started.
. 2017-05-23 18:56:08.266 Executing user defined command on command session.
. 2017-05-23 18:56:08.266 [Shell] Changing directory to "//xxxxxx".
> 2017-05-23 18:56:08.266 [Shell] cd "//xxxxxx" ; echo "WinSCP: this is end-of-file:$?"
! 2017-05-23 18:56:08.267 [Shell] cd: //xxxxxx: EDC5129I No such file or directory.
< 2017-05-23 18:56:08.267 [Shell] WinSCP: this is end-of-file:1
* 2017-05-23 18:56:08.267 [Shell] (ECommand) Error changing directory to '//xxxxxx'.
* 2017-05-23 18:56:08.267 [Shell] Command 'cd "//xxxxxx"'
* 2017-05-23 18:56:08.267 [Shell] failed with return code 1 and error message
* 2017-05-23 18:56:08.267 [Shell] cd: //xxxxxx: EDC5129I No such file or directory..
< 2017-05-23 18:56:08.267 Script: Error changing directory to '//xxxxxx'.
< 2017-05-23 18:56:08.267 Command 'cd "//xxxxxx"'
< 2017-05-23 18:56:08.267 failed with return code 1 and error message
< 2017-05-23 18:56:08.267 cd: //xxxxxx: EDC5129I No such file or directory..
> 2017-05-23 18:56:08.268 [Shell] cd //-JES.intrdr ; echo "WinSCP: this is end-of-file:$?"
< 2017-05-23 18:56:08.269 Script: cd: //-JES.intrdr: EDC5129I No such file or directory.
! 2017-05-23 18:56:08.269 [Shell] cd: //-JES.intrdr: EDC5129I No such file or directory.
< 2017-05-23 18:56:08.269 [Shell] WinSCP: this is end-of-file:1
* 2017-05-23 18:56:08.269 (ETerminal) Command 'cd //-JES.intrdr'
* 2017-05-23 18:56:08.269 failed with return code 1 and error message
* 2017-05-23 18:56:08.269 cd: //-JES.intrdr: EDC5129I No such file or directory..
< 2017-05-23 18:56:08.269 Script: Command 'cd //-JES.intrdr'
< 2017-05-23 18:56:08.269 failed with return code 1 and error message
< 2017-05-23 18:56:08.269 cd: //-JES.intrdr: EDC5129I No such file or directory..
. 2017-05-23 18:56:08.270 Script: Failed
> 2017-05-23 18:56:08.584 Script: exit
. 2017-05-23 18:56:08.584 Script: Exit code: 1
. 2017-05-23 18:56:08.584 Closing connection.
. 2017-05-23 18:56:08.584 Sending special code: 12
. 2017-05-23 18:56:08.584 Sent EOF message
. 2017-05-23 18:56:08.585 [Shell] Closing connection.
. 2017-05-23 18:56:08.585 [Shell] Sending special code: 12
. 2017-05-23 18:56:08.585 [Shell] Sent EOF message
Re: Scripting zOS session fails - psFTP works
WinSCP .NET assembly interface requires a use absolute paths.
Do not try to hack it by running cd in a shell.
Use absolute path in the PutFiles.
