Try to push some files via SFTP/WinSCP and handle all exceptions in PowerShell
denis
I am scripting an automation copy via SFTP/WinSCP.
It's working fine, but I would like to have an issue if the SFTP server doesn't connect for example.
Currently, I add this condition in my script :
# Create a WinSCP session
# Upload files
$transferResult = $session.PutFiles("E:\DATA\test\Data\To process\*", $SSH_destination_path)
# Throw on any error
$transferResult.Check()
$result = $transferResult | ConvertTo-Json
echo $result
# Print results
foreach ($transfer in $transferResult.Transfers) {
    $Date = Get-Date -format G
    # Success or error?
    if ($transfer.Error -eq $Null) {
        $Log += ("{0} - Upload of {1} succeeded on the SFTP server {2}`n" -f $Date, $transfer.FileName, $SSH_hostname)
        # Upload succeeded, move source file to backup
        #Move-Item $transfer.FileName $archive_data_path
    } else {
        $ExceptionFlag = $true
        $Log += ("{0} - Upload of {1} failed: {2}`n" -f $Date, $transfer.FileName, $transfer.Error.Message)
If the SFTP server is on, all my files are uploaded.
But I would like to have an exception if the SFTP server can't connect, and my script doesn't do that for the moment.
I was thinking receive an issue with $transfer.Error.
But there is no issue at all, like all files will be copied, but it's not the case.
Here is the result of $transferResult in JSON:
    "Transfers":  [
                          "Destination":  "/lala - Copy.xml",
                          "Touch":  "WinSCP.TouchEventArgs",
                          "Chmod":  null,
                          "Removal":  null,
                          "FileName":  "E:\\DATA\\test\\Data\\To process\\lala - Copy.xml",
                          "Error":  null
                          "Destination":  "/lala.xml",
                          "Chmod":  null,
                          "Removal":  null,
                          "FileName":  "E:\\DATA\\test\\Data\\To process\\lala.xml",
                          "Error":  null
    "Failures":  [
    "IsSuccess":  true
As you can see, there is a null for Error...
But the SFTP server is shutdown, so why I don't have any error here ?
Re: [Powershell] Try to push some files via SFTP/WinSCP and handle all exceptions
It does not look like the server is shut down.
