winscp .net waiting for log update and dispatching events
olegur
I have issues with my script where it says "timeout waiting for winscp to respond" and i am clueless as to what it could be
using .net for powershell btw
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
# Session.FileTransferred event handler
function FileTransferred
    param($e)
    if ($e.Error -eq $Null)
        Write-Host ("Upload of {0} succeeded" -f $e.FileName)
    else
        Write-Host ("Upload of {0} failed: {1}" -f $e.FileName, $e.Error)
    if ($e.Chmod -ne $Null)
        if ($e.Chmod.Error -eq $Null)
            Write-Host ("Permisions of {0} set to {1}" -f $e.Chmod.FileName, $e.Chmod.FilePermissions)
        else
            Write-Host ("Setting permissions of {0} failed: {1}" -f $e.Chmod.FileName, $e.Chmod.Error)
    else
        Write-Host ("Permissions of {0} kept with their defaults" -f $e.Destination)
    if ($e.Touch -ne $Null)
        if ($e.Touch.Error -eq $Null)
            Write-Host ("Timestamp of {0} set to {1}" -f $e.Touch.FileName, $e.Touch.LastWriteTime)
        else
            Write-Host ("Setting timestamp of {0} failed: {1}" -f $e.Touch.FileName, $e.Touch.Error)
    else
        # This should never happen during "local to remote" synchronization
        Write-Host ("Timestamp of {0} kept with its default (current time)" -f $e.Destination)
# Set up session options
    Protocol = [WinSCP.Protocol]::Ftp
    HostName = "FTPHOST"
    PortNumber = 21
    UserName = "FTPUSERNAME"
    Password = "FTPPASSWORD"
try
        # Will continuously report progress of synchronization
        $session.add_FileTransferred( { FileTransferred($_) } )
        #Logging
        $session.DebugLogPath ="C:\WinSCP\Log\winscp-debug.log"
        #$DateTime = Get-Date -format yyyy/MM/dd-HH.mm.ss
        #$session.SessionLogPath ="C:\WinSCP\log\$DateTime-WinSCP.log"
        # Connect
        # Synchronize files
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Local, "\\LOCAL\felles\Timelapse", "/lerftp/", $False)
        # Throw on any error
        $synchronizationResult.Check()
finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host ("Error: {0}" -f $_.Exception.Message)
    exit 1
and i attached my debug log
olegur
timeout
tried timeout now and it seems to have fixed it, was also getting 0x1 error in task scheduler. Thanks :D #lifesaver
