Timeout Syncing Large Folder
brooks693
Good evening
I am trying to synchronise a folder using the command "synchronize remote "E:\WebFiles" /Paperwork" in a script file.
It begins comparing the files in the 2 folders but due to the large number of files included it now errors with the following
< 2017-06-27 19:36:12.891 421 No-transfer-time exceeded. Closing control connection.
Is there anyway to remove this no transfer time in a script?
Cheers
Re: Timeout Syncing Large Folder
That's server-side error.
