Need to turn off "List Directory" in WinScp scripting?
stealth
Utah
Having errors getting and putting files on a vendors site, this is what they tell me we need to do:
"I have seen this before where it does try to list the directory within Filezilla and WinSCP. You may want to google or look within help on WinSCP to see if there is a list setting you can disable?"
I don't see how to turn off List directory which seems to be default functionality with WinScp? Anyone know how to turn this off esp in the automated scripting mode?
Re: Need to turn off "List Directory" in WinScp scripting?
