Assertion failed bug
nebot
Seattle, WA, USA
Recently opened WinSCP and copying files does not have an issue. Upon trying to move a file from the server to local, it blows up with the error "Assertion failed: (FProgressData->Operation == foCopy) || (FProgressData->Operation == foCalucalteSize),file core\Queue.cpp, line 2250
The same issue occurs with the debug version i have from you and the location line are from that version. 5.9.5
the trace files do not appear to have any meaningful data within them.
nebot
Seattle, WA, USA
Re: Assertion failed bug
Do you have any reason to run the debug version?
Yes, you provided it to me for another issue related to the program dumping when a host is attached and can no longer connect or resolve DNS for the system.
It was for the previous version and while i can reproduce this behavior in both the debug (5.10 build 7391) and normal (5.9.5) i cannot reproduce it in the 5.9.6 (build 7601) version.
By "this behavior" are you referring to "program dumping when a host is attached"?
Can you reproduce the behavior with 5.10.2?
