Could not retrieve file information on alot uploads
***UPDATE***
Attached Debug Log File, however doesn't have much more information I'm afraid
WinSCP Version: 5.9.6 Portable GUI
Source Server: Windows 2008 R2 X64
Destination Server: Linux FTP/Web Server
Errors:
"Could not retrieve file information"
and
"The system cannot find the path specified"
Description:
I'm trying to upload a large amount of local data to the resources folder on an FTP server (99% PDF's).
The resources folder is empty to start with so the application doesn't have to worry about analyzing what's already there, comparing, overwriting etc....
Anyway I saw a fair number of the errors shown above so I hit Skip all to get as much as I can up there for now.
In the case of: "The system cannot find the path specified"
I pasted the exact path from the log for two entries with this error into windows explorer and the file opened no problem.
I also tried manually verifying the path for one of the files and copied it with another FTP program and it worked fine.
However I want to use WinSCP since I am developing a PowerShell script to automate this and transfer any updates daily.
As far as: "Could not retrieve file information"
I don't have a clue...
I know the path's are pretty long
Standard, Debug_1 and Debug_2 Logs attached but here are two examples.
Examples:
Example of "Could not retrieve file information":
Example of "The system cannot find the path specified":
Kenny
FYI
For the hell of it I just downloaded the 5.10.2 beta and try to transfer New and Updated Files only, got the same errors as 5.9.6
Errors:
and
Description:
Examples:
< 2017-07-10 13:40:09.497 257 "/public_html/resources/All Dealers/(A) Firearm Mfg.-Round - PPE (MSDS.TDS.DRAWINGS)/Firearm Mfg.-Round (MSDS.TDS.Drawings)/FN Herstal/MK16 & MK17/MK16 & MK17 - MMR-Blank-NMR-RVR/MK16 Conversions - MMR-Blank-NMR-RVR" is your current location
> 2017-07-10 13:40:09.497 TYPE A
< 2017-07-10 13:40:09.575 200 TYPE is now ASCII
> 2017-07-10 13:40:09.575 PORT 192,168,10,18,33,125
< 2017-07-10 13:40:09.637 200 PORT command successful
> 2017-07-10 13:40:09.637 MLSD
< 2017-07-10 13:40:09.793 150 Connecting to port 8573
< 2017-07-10 13:40:09.793 226-Options: -a -l
< 2017-07-10 13:40:09.793 226 2 matches total
. 2017-07-10 13:40:09.793 Data connection closed
. 2017-07-10 13:40:09.793 type=cdir;sizd=4096;modify=20170710163912;UNIX.mode=0755;UNIX.uid=501;UNIX.gid=501;unique=33c0b671g4427bc; .
. 2017-07-10 13:40:09.793 type=pdir;sizd=4096;modify=20170710163957;UNIX.mode=0755;UNIX.uid=501;UNIX.gid=501;unique=33c0b671g4427bb; ..
. 2017-07-10 13:40:09.793 Could not retrieve file information
. 2017-07-10 13:40:09.793 Copying files to remote side failed.
. 2017-07-10 13:40:09.793 Got reply 2004 to the command 4
* 2017-07-10 13:40:09.793 (ExtException) **Could not retrieve file information**
* 2017-07-10 13:40:09.793 Copying files to remote side failed.
. 2017-07-10 13:40:09.793 Asking user:
. 2017-07-10 13:40:09.793 Error transferring file 'D:\Company\inSync Share\Company-Markting\All Dealers\(A) Firearm Mfg.-Round - PPE (MSDS.TDS.DRAWINGS)\Firearm Mfg.-Round (MSDS.TDS.Drawings)\FN Herstal\MK16 & MK17\MK16 & MK17 - MMR-Blank-NMR-RVR\MK16 Conversions - MMR-Blank-NMR-RVR\01-2550_C FN SCAR Conversion Kit TL.PDF'. ("Could not retrieve file information","Copying files to remote side failed.")Example of "The system cannot find the path specified":
> 2017-07-10 13:44:19.567 TYPE I < 2017-07-10 13:44:19.645 200 TYPE is now 8-bit binary > 2017-07-10 13:44:19.645 PORT 192,168,10,18,33,143 < 2017-07-10 13:44:19.723 200 PORT command successful . 2017-07-10 13:44:19.723 Can't open file 'D:\Company\inSync Share\Company-MARKTING\All Dealers\(A) Firearm Mfg.-Round - PPE (MSDS.TDS.DRAWINGS)\Firearm Mfg.-Round (MSDS.TDS.Drawings)\FN Herstal\MK16 & MK17\MK16 & MK17 - MMR-Blank-NMR-RVR\MK16 Conversions - MMR-Blank-NMR-RVR\TDS_01-2550 FN SCAR MK16 (MMR_BLANK).PDF'. . 2017-07-10 13:44:19.723 System Error. Code: 3. . 2017-07-10 13:44:19.723 The system cannot find the path specified . 2017-07-10 13:44:19.723 Copying files to remote side failed. . 2017-07-10 13:44:19.723 Got reply 4 to the command 4
Kenny
FYI
