How to count folders recursively
ssAshkea
uSaka
Already the whole day I am excruciated I can not understand as to count kol-in folders of all.
Recursively
// Connect
session.Open(sessionOptions);
var directory  = session.ListDirectory("/admin");
var filesCount = session.EnumerateRemoteFiles(directory.ToString(), null, EnumerationOptions.AllDirectories);
return fileCount;
Such code outputs such a message to the log
WinSCP.Session+<DoEnumerateRemoteFiles>d__73
Re: How to count folders recursively
I do not know what is "kol-in folders", but this may help:
int directoriesCount =
    session.EnumerateRemoteFiles(directory, null, EnumerationOptions.AllDirectories | EnumerationOptions.EnumerateDirectories)
        .Where(file => file.IsDirectory)
        .Count();
ssAshkea
I apologize, I wanted to write the number of folders and files
I'll try your code, the library you have is very powerful, only my weak knowledge in C# code does not allow to open up all the potential
ssAshkea
uSaka
Your method does not help produce an error
Error listing directory 'WinSCP.RemoteDirectoryInfo'.
No such file or directory.
Error code: 2
Error message from server: No such file
What to do?
ssAshkea
uSaka
ssh
What can you advise me?
And how correctly to specify a directory the absolute way is correct?
Example:
/home/user/
OK, I've missed that the directory is result of session.ListDirectory is your code.
You have to pass a path as a string to the first argument of session.EnumerateRemoteFiles.
Like:
session.EnumerateRemoteFiles("/home/user/")
ssAshkea
uSaka
And again an error
No overload for method 'EnumerateRemoteFiles' takes 1 arguments. "[String: 16; Column: 19]
Now I have this code
// Setup session options
    Protocol = Protocol.sftp,
    HostName = "server.com",
    UserName = "user",
    Password = "pass",
     SshHostKeyFingerprint = "ssh-rsa 2048 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:1f"
   // Connect
    var directory  = session.ListDirectory("/home/user/");
    //var filesCount = session.EnumerateRemoteFiles(directory.ToString(), null, EnumerationOptions.AllDirectories);
    //var directoriesCount = session.EnumerateRemoteFiles(directory.ToString(), null, EnumerationOptions.AllDirectories | EnumerationOptions.EnumerateDirectories).Where(file => file.IsDirectory);
    return filesCount.Count()  ;
    session.Close();
What is wrong?
OK, so like this:
    "/home/user/", null,
ssAshkea wrote:
1) all the files put in the list of recursive?
I do not understand.
Their names/paths or contents? Please be clear!
If paths, this will do:
var options =
    EnumerationOptions.EnumerateDirectories;
var filesAndDirectories =
    session.EnumerateRemoteFiles(directory, null, options);
var filenames = filesAndDirectories.Select(file => file.FullName);
File.WriteAllLines(outputFile, filenames);
ssAshkea
uSaka
Yes I want to get names and ways of an example:
/home/site.com/file1
/home/site.com/file2
/home/site.com/file3
