Moving Files in Remote Directory Failing.
coling123
Hi all,
sorry to be dense but can't make this work. Using script and FTPS to login to remote server. Land in TagLabel directory. Copy *.pdf to local directory and then move remote files to a sub directory called archive and disconnect. I can get the files but get an error when trying to move the remote files that "The system cannot find the path specified."
Script looks like this:-
# Connect
open ftpes://username:password@ftp.site.com/
# Change remote directory
cd /TagLabel
#Change local directory
lcd C:/TestFTPVTTagLabel
# Download file to the local directory
get *
mv * archive/
# Disconnect
close
# Exit WinSCP
< 2017-08-01 15:30:29.398 226 Transfer complete.
. 2017-08-01 15:30:29.402 Download successful
. 2017-08-01 15:30:29.402 Transfer done: '/TagLabel/Godady139.pdf' [103940]
> 2017-08-01 15:30:29.402 Script: mv *.pdf archive/
. 2017-08-01 15:30:29.402 Retrieving directory listing...
> 2017-08-01 15:30:29.402 TYPE A
< 2017-08-01 15:30:29.423 200 Type set to A.
> 2017-08-01 15:30:29.423 PASV
< 2017-08-01 15:30:29.444 227 Entering Passive Mode (40,71,229,79,78,44).
> 2017-08-01 15:30:29.444 LIST -a
. 2017-08-01 15:30:29.445 Connecting to 40.71.229.79:20012 ...
< 2017-08-01 15:30:29.464 150 Opening ASCII mode data connection.
. 2017-08-01 15:30:29.471 Session ID reused
. 2017-08-01 15:30:29.472 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=AESGCM(256) Mac=AEAD
. 2017-08-01 15:30:29.472 TLS connection established
. 2017-08-01 15:30:29.485 Data connection closed
. 2017-08-01 15:30:29.485 03-02-17 03:57PM 103940 Godady139.pdf
< 2017-08-01 15:30:29.487 226 Transfer complete.
. 2017-08-01 15:30:29.487 Directory listing successful
. 2017-08-01 15:30:29.487 ..;D;0;1899-12-30T05:00:00.000Z;0;"" [0];"" [0];---------;0
. 2017-08-01 15:30:29.487 Godady139.pdf;-;103940;2017-03-02T19:57:00.000Z;1;"" [0];"" [0];---------;0
. 2017-08-01 15:30:29.487 Moving file "Godady139.pdf" to "archive/Godady139.pdf".
> 2017-08-01 15:30:29.487 RNFR /TagLabel/Godady139.pdf
< 2017-08-01 15:30:29.505 350 Requested file action pending further information.
> 2017-08-01 15:30:29.505 RNTO /TagLabel/archive/Godady139.pdf
< 2017-08-01 15:30:29.526 550 The system cannot find the path specified.
. 2017-08-01 15:30:29.526 Asking user:
. 2017-08-01 15:30:29.526 Error moving file 'Godady139.pdf' to 'archive/Godady139.pdf'. ("The system cannot find the path specified. ")
< 2017-08-01 15:30:29.526 Script: Error moving file 'Godady139.pdf' to 'archive/Godady139.pdf'.
< 2017-08-01 15:30:29.526 Script: The system cannot find the path specified.
. 2017-08-01 15:30:29.526 Script: Failed
. 2017-08-01 15:30:29.526 Script: Exit code: 1
. 2017-08-01 15:30:29.538 Disconnected from server
Re: Moving Files in Remote Directory Failing.
And does the subfolder exists?
What does ls archive say?
