Synchronization Scripting not skipping existing files via FTP
NickM
Montreal
Hey all,
I created a simple winscp script to synchornize local files from a machine to a remote FTP server.
option batch abort
# We tell it which FTP to connect to
open mediasync
# We tell it to synchronize local to Remote path
synchronize -filemask="*.jpg" -criteria="time" -resumesupport="on" remote D:\FILES\Thumbnails /Thumbnails
The files get uploaded however every time the script re-runs it will reupload all the files all over again.
Alternatively I've tried using -criteria="size" however get the same behavior.
Are there any known limitations that would be causing this to happen?
NickM
Montreal
In case other come across this same issue I wanted to update this thread with how I managed to get this working.
Instead of using the FTP protocol I ended up simply switching to a jailed SSH connection and used SCP protocl (instead of FTP).
Once I did this everything started working properly. I suspect that the FTP protocol may be limited to not allow the fetching of proper timestamps.
Hope this helps someone else in the future.
Thanks!
