Throwing errors under Perl
golfkilo
I have a problem with error handling in perl
All the latest versions of WinSCP, ActivePerl, Perl modules...
I am using this example with sftp server running under Centos. The Windows machine is 2012R2
https://winscp.net/eng/docs/library_perl#example
Well all works apart from error handling...
For error handling testing I tried non existing file names, etc
$transferResult->Check();
Nothing happens here... Nada. What am I missing?
I did the same tests with the powershell example script.. And it works exactly as expected!
( https://winscp.net/eng/docs/library_powershell#example )
It throws the errors like a dream.
The problem is I have to use perl... any idea what could be wrong? I suspect something in Win32::OLE;
Anyone got an idea?
golfkilo
I think I have solved it myself :)
The sample code needs some amending...
At the beginning it needs to add for example:
Win32::OLE->Option(Warn => sub {goto CheckError});
And then have something like this at the end of your script...
CheckError:
#Just an example what you might want to do...
my $oleerror = Win32::OLE->LastError;
print "$oleerror\n";
$session->Dispose();
exit;
Ram
Hi golfkilo,
Tried plugging in the solution you posted for error handling. The perl script throws an error on Check Error. i.e. Can't find label CheckError
Would you be able to share some sample codes to catch the session open or transfer result errors please?
CheckError:
exit;[/quote]
RamAjay
I figured it out the error. I was calling Win32::OLE->Option(Warn => sub {goto CheckError}); from the sub routine which was calling the session->Open. I had to move that out of the sub routine to capture the errors.
i.e.
sub sftp{
Win32::OLE->Initialize(Win32::OLE::COINIT_OLEINITIALIZE);
my $session = Win32::OLE->new('WinSCP.Session') || die "Can't create winscp sessoion: ", Win32::OLE->LastError;
my $consts = Win32::OLE::Const->Load($session);
my $sessionOptions = Win32::OLE->new('WinSCP.SessionOptions')|| die "Can't open winscp
sessoionOptions: ", Win32::OLE->LastError;
$sessionOptions->{'Protocol'} = $consts->{'Protocol_Sftp'};
$sessionOptions->{'HostName'} = $Server;
$sessionOptions->{'UserName'} = $UserId;
$sessionOptions->{'Password'} = $SSHPassword;
$sessionOptions->{'SshHostKeyFingerprint'} = $SSHHostKeyFingerPrint;
$session->Open( $sessionOptions);
my $OLEConnectionError = Win32::OLE->LastError;
if ("$OLEConnectionError" ne "0")
print "$OLEConnectionError","\n";
exit 13;
