Excel file corruption after download
marjesusa2002
Hi;
We connect to an FTP and download 2 excel files a day. One file is fine but always the other became corrupted. I can see on the logs the file size before and after the transfer and are the same; however when you go to the directory the file size is considerably smaller. No errors are reported on the logs. I tried other scripting tool and it download the files with no issues. We have several scripts on Winscp and this only happens on this excel files. I attached a screenshot of the logs;
the file corrupted is named SBLMSR23030004658896.xlsx
Re: Excel file corruption after download
Please attach a full session log file showing the problem (using the latest version of WinSCP). Make the log show download of both files.
Also, can you reproduce the problem using manual download in WinSCP GUI?
Fredu
Is there any solution?
Hi admin,
I have the same problem reported by marjesusa2002, please could you share me the answer if you have already solved it?
Thank you!!
Re: Is there any solution?
As you can see, marjesusa2002 never provided the log file I have asked for. Neither you did.
