The get command fails if destination directory does not exist
alrisk
Hello.
The download via get command fails if destination directory (in my case on Windows) does not exist yet.
If I create destination directory by hand then download works just fine.
How can I make it work?
------------- DownloadWholeDirectoryScript.txt -------------
open sftp://someUser:somePassword;@someHost -hostKey="ssh-rsa 2048 x:x:x:x:x:x:x:x:x:x:x:x:x:x:x:x"
get /foo/bar/* C:\someDirectory\
------------- Console lauched as administrator -------------
cd C:\Program Files (x86)\WinSCP
C:\Program Files (x86)\WinSCP> winscp.com /ini=nul /script=C:\DownloadWholeDirectoryScript.txt
  Searching for host...
  Connecting to host...
  Authenticating...
  Using username "someUser".
  Authenticated.
  Starting the session...
  Session started.
  Active session: [1] someUser@someHost
  Can't create file 'C:\someDirectory\someFile.txt'.
  System Error.  Code: 3.
  The system cannot find the specified path
[/b]
Re: The get command fails if destination directory does not exist
Yes, the destination directory have to exists. That's it.
You can, of course, use mkdir Windows command from a wrapping batch file, to create the directory, before starting WinSCP script.
