Fail to send using passphrase when executed from SSIS Script Task in a deployed package
nashtf
I'm using a C# script task in SSIS 2012 which uses a WinSCP assembly. It works fine using SFTP without a public key, but passing the Passphrase parameter causes it to fail. I've tried generating the SessionOptions first before opening the connection, but it fails. I've eliminated possibility of file paths and permissions as it runs perfectly well from my local machine, but it fails when deployed to the server. Server packages work perfectly fine when there is a password passed in, but fail with Passphrase. Is there an issue with the Passphrase parameter and certain build versions?
Re: Fail to send using passphrase when executed from SSIS Script Task in a deployed package
Sorry, but "fail" is too vague.
I don't even get to creating the session. I've stripped down my code to this and it fails. The exception message doesn't even get printed to the report when running through Integration Services Catalogs. This runs perfectly fine on my local machine through Visual Studio debug mode.
        public void Main()
            try
                    Protocol = Protocol.Sftp,
                    HostName = "host.site.com",
                    UserName = "user",
                    SshHostKeyFingerprint = "ssh-rsa 2048 fingerprint"
                    PrivateKeyPassphrase = "password",
                    SshPrivateKeyPassphrase = @"C:\Path\To\Key"
            catch (Exception e)
                Dts.Events.FireError(-1, "Session setup", e.Message, String.Empty, 0);
Still, "it fails" is too value. You must get some error message or some error code at least. I do not believe that all information that you have is "it fails".
