unable to upload
rvergin
unable to upload
I am unable to upload a file. The error message the upload was successful but error occurred while setting the permissions and/or timestamp. I set preservetimestamp to false. I am using vb.net. I still get the error. I don't see where I can turn off permissions.
revergin
Southfield, MI
Re: unable to upload
vendor states they require SSH2. Is that a problem for WinSCP? or a contributing factor to this problem?
Reply with quote E-mail
rvergin
Here is my code. I am unable to find the log file.
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Try
' Setup session options
With sessionOptions
.Protocol = Protocol.Sftp
.HostName = "host"
.UserName = "user"
.Password = "pass"
.PortNumber = 22
.SshHostKeyFingerprint = "ssh-rsa 2048 d5:e9:b2:29:16:a3:09:fb:e8:6d:67:72:be:88:c8:d6"
End With
Using session As New Session
session.SessionLogPath = "p:\comerica\log.xml"
' Connect
session.Open(sessionOptions)
' Upload files
transferOptions.TransferMode = TransferMode.Ascii
transferOptions.PreserveTimestamp = False
transferResult = session.PutFiles("p:\Comerica\DataVault\ACH\TPEPILOCOMOTVSFTP.EFTCLAIMS 09-06-2017 - Copy.txt", "/To_Comerica/TPEPILOCOMOTVSFTP.txt")
'https://sftp.comerica.com/?token=20079AB7-94AE-11e7-80E2-42F2E966EE8F#/To_Comerica/
' Throw on any error
transferResult.Check()
' Print results
For Each transfer In transferResult.Transfers
Debug.Print("Upload of {0} succeeded", transfer.FileName)
Next
End Using
'Return 0
Catch 'e As Exception
Console.WriteLine("Error: {0}", e)
'Return 1
End Try
End Sub
rvergin
Try
With sessionOptions
.HostName = "host"
.UserName = "user"
.Password = "pass"
.PortNumber = 22
End With
' Connect
' Upload files
' Print results
Next
End Using
'Return 0
'Return 1
End Try
End Sub
Vendor states that the error may be du to the fact that the file I am uploading is in a polled folder and is almost immediately moved to a production error. It may be happening before the WinSCP upload process has time to set the permissions on the file. How do I turn the setting of permissions off?
Day 2
Any body know how to turn off permission settings on a file upload?
Anonymous wrote:
Day 2
still day 2 actually 6
set transferoptions.filepermissions = nothing
still get error.
Now do Any body know how to set the ignore errors ?
revergin
Southfield, MI
end of day 2 (6)
No response yet. I have fixed my problem. I still don't know where the log file is.
So do you still need any help?
Instructions for obtaining the session log is in my previous reply.
