Error Listing Directory
Guest123
I've been trying to download a zip file to a local drive but it keeps showing "Error listing directory".
And I cant seem to figure out what is the problem as the file is in the correct directory.
Here is what I wrote for the .bat file and .txt file
.bat
:while1
cd D:\syncscripts
if 1 leq 2 (
set _my_datetime=%date%_%time%
set _my_datetime=%_my_datetime: =_%
set _my_datetime=%_my_datetime::=%
set _my_datetime=%_my_datetime:/=_%
set _my_datetime=%_my_datetime:.=_%
D:\WinSCP\winscp /script="D:\syncscripts\download_test.txt" /parameter D:\PCIOS_LOGS /opt/tacs/d/PCIOS/PCCAU_ARCHIVE_LOG/%date:~7,2%%date:~4,2%%date:~10,4%/
timeout /t 3600
goto :while1
pause
.txt
# Being intended for interactive session, we are not enabling batch mode
# Connect
open PCIOS_session -rawsettings SendBuf=0
# Synchronize paths provided via environment variables
option batch continue
synchronize local -mirror -nopermissions -speed="20" -filemask="*.zip" -criteria="size" "%1%" "%2%"
Thanks for your help in advance!
Re: Error Listing Directory
