SSIS 2012 + WinSCP
Khaled merdassi
SSIS 2012 + WinSCP
Hi all,
I tried to use the WinSCP in a SSIS C# script task and i am getting this message error :
Exception has been thrown by the target of an invocation.
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams)
at Microsoft.SqlServer.Dts.Tasks.ScriptTask.VSTATaskScriptingEngine.ExecuteScript()
The version of .Net referenced by the script is .Net4, and please note that i can't use earlier versions, it's a problem with the .Net version and what version of WinSCP assembly work fine with .Net 4
Best regards,
Ankur wrote:
Were you able to resolve this issue Martin? If yes, please suggest how?
As you can see, I never got a response my question above. Can you answer it?
