Not able to retrieve file from server to local using WINSCP through python code
vickyRocker
USA
I am trying to retrieve a csv file from server using WINSCP through python code -
Here is my command -
s = start /wait cmd /cd C:\dir1\WinSCP\winscp.com /command "open sftp://username:password@hostName.com/" "get /dir1/dir2/dir3/file.csv C:\Users\eclipse-python\project\src\dir1\dir2\ " "exit"
And I am doing os.system(s)
After i execute the command, there is a cmd pop up that appears for a second and then disappears. Also the file.csv is not retrieved.
I
Re: Not able to retrieve file from server to local using WINSCP through python code
The cmd has no /cd switch. You probably wanted to use /c.
Though it makes no sense to run winscp.com via cmd anyway. Run it directly.
