Timeout detected and connection failed
Ji-Eun
I was having a timeout detected error when I tried to connect. Hence I tried to change the timeout limit and hope the result would change. However, after I change the timeout limit to 30 seconds I got a Connection Failed error.
"A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. Connection failed."
May I know is there a way to fix this? I'm new to WinSCP
