Stream file rather than downloading
I wish I could do this on Windows as well.
GetFile
method with FTPS.
GetFileToDirectory
method.
FtpWebRequest
class. Though it has its limitations. For example it does not support TLS/SSL session resume. What can indeed be a showstopper (now or later).
PutFile
method so we're only catching those during our upload loop and not everything.
foreach (var file in files) { try { var transferfilename = Approvals.GetTransferName(); var transfercontent = Approvals.GetTransferContent(file.Content); var remotepath = $"{Configuration["SftpInbox"]}/{transferfilename}"; var byteArray = Encoding.ASCII.GetBytes(transfercontent); var stream = new System.IO.MemoryStream(byteArray); session.PutFile(stream, remotepath, options); await Approvals.SetTransferNameAsync(file.RowKey, transferfilename, DateTime.UtcNow); await Approvals.SetStatusAsync(file.RowKey, CitStatus.Transferred); } catch (Exception ex) { //I catch everything here, but I'm only concerned with the exception //throw for this single file upload await Approvals.SetStatusAsync(file.RowKey, CitStatus.TransferError); } }
Session.PutFile
throws the same exceptions as Session.PutFiles
does:
This is exactly our issue.FTPS (and streaming) is supported by the native .NETFtpWebRequest
