Put Files not working in Amazon AWS server.
ramakrishna
india
Hi, Team,
Getting session log out and put files not working in Amazon AWS server. But, its working fine in Local.
I am using 5.9.6 version.
Below is my code
Protocol = WinSCP.Protocol.Sftp,
HostName = "sftp.XXXXXX.com",
PortNumber = 22,
UserName = "XXXXXXXXX",
Password = "XXXXXXXXXX",
SshHostKeyFingerprint = "XXX-XXa 1098 xx:xx:xx:xx:xxx:xxx:xx:xx:xx:",
// Connect
session.Open(sessionOptions);
// Your code
session.DebugLogPath = Server.MapPath("Temp/") + "logWinSCP";
// Upload files
TransferOptions transferOptions = new TransferOptions();
transferOptions.TransferMode = TransferMode.Binary;
TransferOperationResult transferResult = null;
transferResult = session.PutFiles(Server.MapPath("Temp/" + _fileName), "/users/adminTest/sample/", false, transferOptions);
// Throw on any error
transferResult.Check();
Ram
ramakrishna
india
Re: Put Files not working in Amazon AWS server.
Thanks for the response Martin,
In a server when I'm trying to connect FTP box with WINScp client, I'm able to connect and get and put files. But on the same server when I'm trying to put files using WINSCP .net assembly, I'm getting connection timed out the issue.
I thought like it may be the firewall which blocks but in that scenario, I should not connect to FTP box with WINSCP client also.
Could you please let me know what could be the problem?
for your reference.
Below is my code
PortNumber = 22,
// Connect
// Your code
// Upload files
Rahul.
We need log files! Both from GUI and the code.
And note that FTP is not SFTP. You are confusing those two.
ramakrishna
india
Please find the attached log file of GUI, from code, the log file is not generating (it's saying session timeout).
I am using SFTP not FTP its typing issue.
Rahul.
  • sftp.XXXXXX.com.log (20 KB, Private file)
Description: GUI Log file.
ramakrishna
india
Hi Martin, Waiting for your replay.
Ram.
ramakrishna
india
Hi, Thanks for your reply.
I tried with
session.ExecutableProcessUserName = "XXXX";
session.ExecutableProcessPassword="XXXXXX";
Error message changed and now I am getting
"System.ComponentModel.Win32Exception (0x80004005): Access is denied" error.
and I changed IIS impersonation permissions levels also still I am facing the same issue.
Rahul.
Without an exception callstack, it's difficult to tell what causes the problem.
Where do you have winscp.exe stored? Does the local account have permissions to that file?
