WebDav over Powershell with 2 Factor auth
CSDBA
Perhaps someone could point me in the right direction. I'm trying to connect to a WebDav host using WinSCP & Powershell
Connecting to this WebDav host works 100% in the WinSCP client itself. i specify the location of the certificate, put the host address and remote directories in under advanced. when i then connect I am prompted for 2 passwords. First the certificate PW, then the user / pass for the webdav host itself.
I would now like to do this via powershell. I noticed that you can generate the session code from the client - see below
the generated code specified the webdav host username and the certificate password. The actual webdav host password is not specified.
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
# Set up session options
Protocol = [WinSCP.Protocol]::Webdav
HostName = "cert.domainname.com"
PortNumber = 443
UserName = "hostusername"
Password = "certificatepassword"
WebdavSecure = $True
TlsClientCertificatePath = "C:\OpenSSL-Win64\certificate"
try
# Connect
# Your code
finally
$session.Dispose()
In the end when I try to connect i get the following error
Exception calling "Open" with "1" argument(s): "SSL handshake failed, client certificate was requested: SSL error: sslv3 alert handshake failure
Connection failed."
At line:20 char:5
+ $session.Open($sessionOptions)
+ CategoryInfo : NotSpecified: (:) [], MethodInvocationException
+ FullyQualifiedErrorId : SessionRemoteException
If it works with the client surely it can be done using the .net assembly and PS
thanks in advance for any help or suggestions
