Unable to dismount Veracrypt volume after being referenced by WinSCP
donr
I'm running Windows 8.1 and WinSCP v5.11.1. This problem has existed for several versions of WinSCP.
I copied files from a remote system to a local drive that is a VeraCrypt volume. The VeraCrypt volume is mounted and running as a local drive letter on my workstation. The files are transferred without problems. I move out of the VeraCrypt-mounted drive on the Local side of WinSCP. I am then unable to dismount the VeraCrypt volume until I exit WinSCP completely. It then dismounts without issues.
What needs to be done so I don't have to exit WinSCP to dismount the VeraCrypt volume? Thanks.
donretzlaff@gmail.com
Re: Unable to dismount Veracrypt volume after being referenced by WinSCP
Thanks for your post.
https://winscp.net/tracker/1560
