Timout during synchronize direcory structure
Paul Maechler
Hi
I try to sync a remote tree ( 10 folders / ~150 files / 600 MB).
Command I use in script: synchronize remote -delete i:\web\transfer /web/mx/files/transfer
Finally it works after certain timeouts. What can I do to fix that ?
I have no problems if there are no subdirs.
Any help is highly appreciated.
Regards
paul
-- Script result ---------------------------
batch on
Connecting to download.hostname.ch ...
Connected
Starting the session...
Session started.
Active session: [1] mx@download.hostname.ch
Comparing...
Local 'i:\web\transfer\Silvo' => Remote '/web/mx/files/transfer/Silvo'
Lost connection.
Timeout detected. (data connection)
(A)bort, (R)econnect (5 s): Reconnect
Connected
Session started.
Lost connection.
Connected
Session started.
Nothing to synchronize.
Session 'hostname@download.hostname.ch' closed.
No session.
