get -delete not working
tech543
I currently have a winscp script to download any zip files from a remote location that was added within the last 30 minutes. I need to have these files deleted after a successful download but
for some reason get - delete is not working. Anybody have any suggestions?
Here is the cmd being used:
cd /remotedirectory
lcd C:\localdirectory
get -delete -filemask="*>30N" /remotedirectory*.zip
NOTE: I have the script working without -delete. when adding -delete, zip files still transfer but do not delete afterwards from the remote directory.
Re: get -delete not working
