Upload multiple files to remote server SFTP
vish
Need help on understanding how to send multiple files at some regular time interval.
I was referring to Using WinSCP scripting provided @ Uploading a list of files
Here I could not get what these files are and what are the contents?
script.tmp and list.txt
Example script from site
@echo off
set SESSION=sftp://user:password@example.com/
set REMOTE_PATH=/home/user/
echo open %SESSION% >> script.tmp
rem Generate "put" command for each line in list file
for /F %%i in (list.txt) do echo put "%%i" "%REMOTE_PATH%" >> script.tmp
echo exit >> script.tmp
winscp.com /script=script.tmp
set RESULT=%ERRORLEVEL%
del script.tmp
rem Propagating WinSCP exit code
exit /b %RESULT%
My script looks like this and needs a tweak to send multiple files at regular interval
@echo off
"D:\WinSCP3\WinSCP.com" ^
  /log="D:\WinSCP3\Logs\WinSCP.log" /ini=nul ^
  /command ^
    "open sftp://d111111:aaaa%%2A00@localhost:9222/ -hostkey=""ssh-ed25519 256 ce:b4:5d:24:94:6b:75:h0:87:57:4v:55:19:21:99:a1""" ^
    "lcd C:\Users\111111\Desktop" ^
    "cd /home/d111111" ^
    "put -neweronly -resumesupport=10 RemoteFileTransfer.xlsx" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
Thanks in advance
Re: Upload multiple files to remote server SFTP
Sorry, but it's not clear what is your specific problem.
So you have a problem with scheduling or with selecting the files to transfer?
The script.tmp is a temporary file generated by the batch file.
The list.txt contains list of file names.
Though I'm not sure that you need this. It looks like you just want to hard code the file names to the script.
WinSCP GUI can generate such a script file for you:
https://winscp.net/eng/docs/guide_automation#generating
For scheduling, see:
Schedule file transfers (or synchronization) to FTP/SFTP server
