Chinese charactersin logfile
knlyngstad
I am running ver. 5.11 with .Net Assembly
Language is English, but all logfiles comes in Chinese.
In my powershell script the logging is enabled with
$session.SessionLogPath = $logfile
I have tried to run the script with standard winscp.exe /console but the result is the same,
only chinese characters in the logfile, I want plain english.
Re: Chinese charactersin logfile
WinSCP uses your Windows UI language by default.
If you want to change this, use Interface\LocaleSafe raw configuration option:
https://winscp.net/eng/docs/rawconfig
$session.AddRawConfiguration("Interface\LocaleSafe", "1033")
