Download files from WebDav with certificate via CLI
Pascal
I have a WebDav folder from which I have to download data once a month. I would like to automate that using Powershell and WinSCP.
I already have a saved session for that, which is working properly, but I can find no way to safe the Certificate Passphrase.
The Script Generator gives me this:
# WinSCP .NET assembly laden
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
Protocol = [WinSCP.Protocol]::Webdav
HostName = "webdav.remotehost.test"
PortNumber = 443
UserName = "User_Name"
Password = "somepwd$123"
WebdavSecure = $True
TlsClientCertificatePath = "C:\Cert\60654_20171012.p12"
$sessionOptions.AddRawSettings("ProxyMethod", "3")
$sessionOptions.AddRawSettings("ProxyHost", "webproxy.company.de")
$sessionOptions.AddRawSettings("ProxyPort", "8080")
try
# Connect
# Your code
finally
$session.Dispose()
Hint: I altered personal information but there is a "$" in the Password which cannot be changed and there is a startfolder. The complete URL looks like this https://webdav.remotehost.test/~0000010656/
Running this gives me the following error: SSL handshake failed, client certificate was requested: SSL error: sslv3 alert handshake failure
Does anyone know if there is anyway to get this running?
Pascal
Re: Download files from WebDav with certificate via CLI
Thank you, but there are still some problems.
1. How can I use the Dollar sign in a password? I tried like this "somepwd`$123"
2. How do I specify the Remote directory?
3. I still get the following error: "Server certificate verification failed: issuer is not trusted" is there another option to ignore that?
Thanks.
Looks ok to me. Do you have any problem with that?
For what?
To verify certificates issues by untrusted authority, use SessionOptions.TlsHostCertificateFingerprint:
https://winscp.net/eng/docs/library_sessionoptions#tlshostcertificatefingerprint
