Sync down specified folder (under subdirs)
Andieboy
Dear All,
I'm new on this forum, altought I'm using winSCP for years. But now, I've faced a problem, I can't solve for days.
I have the following directory structure on a SFTP server:
/reportfiles/XYreports/yyyymmdd/termid_datetimestamp/
Which means, that under XYreports (last fix dirname), there are date-named directories, whereunder there are hundreds of terminalID driven dirnames. All those terminalID subdirectories contains only 1 ZIP file, whise are important for us. But only for specified terminalIDs!
So for exact example:
/reportfiles/XYreports/20171013/AAA123_20171013_091400/
/reportfiles/XYreports/20171013/AAA124_20171013_091500/
/reportfiles/XYreports/20171013/AAA125_20171013_091600/
/reportfiles/XYreports/20171013/AAA126_20171013_091700/
/reportfiles/XYreports/20171013/BBB567_20171013_091800/
/reportfiles/XYreports/20171014/AAA123_20171014_072400/
/reportfiles/XYreports/20171014/AAA124_20171014_072400/
/reportfiles/XYreports/20171015/AAA123_20171015_102200/
and so on. there are only 1 zip under those final subdirectories.
I'm interested on EVERY DAY, only on AAA123 -named terminal's zip file. (and later the BBB556 for example). All others I don't want even download.
My best effort was:
cd /reportfiles/XYreports/20171015/
synchronize -filemask="*AAA123*/" local  ..\transfer\
This one downloads only the AAA123 dir, with the zip inside it. But it works only in 20171015 subdirectory.
I don't want to specify the day, so I want something like
synchronize -filemask="*/*AAA123*/" local  ..\transfer\
But it doesn't work, since the log says: all subdirs are excluded.
How can I do that, guys?
thanks!
Re: Sync down specified folder (under subdirs)
You cannot do this with simple WinSCP scripting.
But it's easy with WinSCP .NET assembly and PowerShell
https://winscp.net/eng/docs/library_powershell
You can start with this example:
https://winscp.net/eng/docs/script_download_files_to_same_folder
And modify it to get something like:
$date = (Get-Date -Format "yyyyMMdd")
$subdirInfos =
    $session.EnumerateRemoteFiles(
        "/reportfiles/XYreports/$date", "AAA123*",
        [WinSCP.EnumerationOptions]::MatchDirectories)
foreach ($subdirInfo in $subdirInfos)
    Write-Host "Downloading from $($subdirInfo.FullName)"
    $session.GetFiles(
        $subdirInfo.FullName + "/*.zip", "C:\transfer\*").Check()
Andieboy
Hi Martin,
thank you for the answer, I was afraid you left the forum and I won't get any answer :)
Okay, I'll try that you mentioned.
I thought, there is some wildcard parametering in path as well, something like:
> synchronize /dir1/dir2/*/getthese*/*.zip
This means, it will download all these directories:
/dir1/dir2/ abc /getthese1/alpha.zip
/dir1/dir2/ abc /getthese2/beta.zip
/dir1/dir2/ cde /getthese8/zeta.zip
/dir1/dir2/ xyz /gettheseYX/omega.zip
and so on..
That would be something logical for me, btw, what is the reason to NOT working that way? (I don't want to change WinSCP, I just want to understand :) )
Thanx again!
You can do this, but it will recreate a remote directory structure locally. What I understand that you do not want to.
