Pasting file path -> error
camper
I'm an Altap Salamander user and used to paste file paths to quickly change directories and select the file indicated by the name. Unfortunately, WinSCP does not support it as smart as Altap Salamander does: WinSCP shows an error when trying to paste a file path - "Directory '<pasted-file-path>' doesn't exist.".
Could you please extend WinSCP that way that at least it will select the directory of the pasted file path (and as a bonus select the file)? Thanks in advance.
srinivasan
Request for Compiling issues
Dear sir,
I got a error for compile winscp 5.11.2 version, i mention that error in below pls give me a solution for compile that source code.
[DCC Error] PasTools.pas(387): E2361 Cannot access private symbol TCustomForm.FTextHeight
[DCC Error] PasTools.pas(392): E2361 Cannot access private symbol TCustomForm.GetTextHeight
[DCC Error] PasTools.pas(547): E2361 Cannot access private symbol TCustomListView.FMemStream
[DCC Error] PasTools.pas(547): E2008 Incompatible types
[DCC Error] PasTools.pas(558): E2361 Cannot access private symbol TCustomTreeView.FMemStream
[DCC Error] PasTools.pas(558): E2008 Incompatible types
[DCC Error] PasTools.pas(569): E2361 Cannot access private symbol TCustomRichEdit.FMemStream
[DCC Error] PasTools.pas(569): E2008 Incompatible types
[DCC Error] PasTools.pas(592): E2361 Cannot access private symbol TApplication.FAppIconic
[DCC Error] PasTools.pas(597): E2361 Cannot access private symbol TApplication.FAppIconic
[DCC Error] PasTools.pas(602): E2361 Cannot access private symbol TApplication.FMainForm
Failed
Elapsed time: 00:00:03.3
Re: Request for Compiling issues
Can you start your own thread for your problem?
This has nothing to do with the topic of this thread.
camper
Re: Pasting file path -> error
I will take a look at this issue.
Unfortunately, this bug still is reproducible in 5.11.3. Is there a corresponding issue in the tracker?
