File mask and hours
Snorky
File mask and hours
Hi.
What a wonderfull tool you made!
I need to get back somes DAT files created within 10 hours from a FTP. My files are named like this TAXAxxxxx.DAT, I checked I've got somes, but I can't figure what I did wrong because there is no any files in my destination folder...
Here is my code :
WinSCPPortable.exe /command ^
    "open ftp://user:pass@myftp/" ^
    "get ../../usr4/account/TAXA*.DAT|*<10H C:\tmpftp\" ^
    "exit"
Thank you!
  • ScreenShot189.jpg (62.02 KB, Private file)
Description: Remote server list of files
Snorky
Hi.
Thank you.
But, sorry it doesn't match...
With this filter, it download a month of.DAT files. (From 06/10/2017 to now), not just 10h...
Snorky
My bad!
I wasn't using the proper version of the exe... With the exe up to date it's work just fine!
Thank you again for your wonderfull product!
