Get only files without extension using script ...
DaMayor
I'm running WinSCP using a script which holds the actions that should be done.
I just want certain files to be downloaded to a local pc
THe files I want to download are those with a specific filemask, and without extension.
Below how the get-command looks like in my script:
option transfer ascii
get *PRODUCT*. C:\Temp\Files\
So, I would expect that alle the files holding the word 'PRODUCT' in the filename and have no extension would be downloaded to C:\Temp\Files\
But When I look at the generated logfile I don't see any file downloaded:
<session xmlns="http://winscp.net/schema/session/1.0" name="MyUser@MyHost" start="2017-11-07T10:18:00.639Z">
Is there anyone who can help me out on this one please?
Thanks in advance.
DaMayor
Re: Get only files without extension using script ...
