Improving performance with AES-NI support
p-st
thanks for the great software!
I'm pretty excited about the AES-NI support, which will be added to PuTTY probably in the next release 0.71. It will be a performance boost because AES decryption/encryption is performed directly by the CPU.
Will there be AES-NI support also in WinSCP?
Regards,
Patrick
Re: Improving performance with AES-NI support
Once the next version of PuTTY is released, we'll integrate it into WinSCP.
(As long as the new code can be compiled using our compiler)
Pyre909
Utah
AES-NI support
Hi Martin,
Would there not be any reason to include AES-NI support by incorporating the latest development snapshot? Or would this not be good practice?
If you do incorporate it I can test for you.
Regards!
Re: AES-NI support
If it was only about adding the new algorithm, I would not mind using a beta version. But as the development code of PuTTY has a lot of ongoing significant changes to the code, I would not dare.
