Unable to map local drive
Abu
Canada
I am having issue with mapping local drive (i.e. C:\)
WinSCP Version details below:
WinSCP 5.11.2 (Build 7781)
Connected to FTP
Re: Unable to map local drive
Do you mean "displaying drive C:"? I assume you have a C: drive, do you? Can you see it in Windows Explorer? Can you post a screenshot?
Yes, I have C: drive but it's not displaying. C: drive is hidden from windows explorer by company policy. Thanks for reply
OK, WinSCP follows that policy.
You can use a hidden raw configuration option Interface\HonorDrivePolicy to override that:
https://winscp.net/eng/docs/rawconfig
I do not understand. This has nothing to do with scripting.
Example how to use the /rawconfig switch is at the end of the page linked in my previous post.
