Store editor text-encoding per session
please make the default encoding of the internal editor configurable per session (like the encoding for filenames). Currently this is a global setting. But I have not yet converted all projects to UTF-8, so I have to manually toggle back and forth (or use the commandline option
I know that a UTF-8 BOM at the beginning of files switches the editor to UTF-8 encoding, but I cannot use this, because it breaks the PHP function
regards,
Klaus
/rawconfig Interface\Editor\Encoding=65001), but this is easy to forget.
header().
regards,
Klaus
