Inability to access subdirectories with WinSCP
b_gray
Maine
Several months ago the WinSCP client stopped being able to access any subdirectories on our sFTP server. The FileZilla and Cyberduck clients do not have any issues accessing these subdirectories. WinSCP will let me create a subdirectory and delete it but will not let me access it. The sFTP server is COPSSH version 3.0.0 running on a Windows Server 2016 Standard with all current patches. The client is WinSCP Version 5.11.2 (Build 7781) (OS 10.0.16299 - Windows 10 Pro) using the commander interface as described in the attached log file. Let me know if you need anything else. Thanks,
Benson
Description: subdirectory access issue
b_gray
Maine
Re: Inability to access subdirectories with WinSCP
Consider using an official Microsoft build of OpenSSH, instead of CopSSH.
https://winscp.net/eng/docs/guide_windows_openssh_server
I installed OpenSSH and it did work correctly with WinSCP. However, the default security settings opened my entire server to anyone using sFTP so I have since removed it. It isn't worth reconfiguring the whole access control structure on my entire folder tree to solve this issue. Thanks anyway,
Benson
What "security settings" are you referring to? What does it mean "opened my entire server to anyone"?
