output from processing
robkof
How become output from processing? If something were synchronized, then make something in batch file. Thanx
<run.bat>
WinSCP.com /script=script.txt
if (something were synchronized) start D:\photos\
<script.txt>
open ftp://name:pass@192.168.0.20:22
cd Camera
synchronize local D:\photos\
Can you please help me?
Re: output from processing
You can enable XML logging and parse it:
https://winscp.net/eng/docs/logging_xml
Though easier is to use a WinSCP .NET assembly from a PowerShell script.
$mode = [WinSCP.SynchronizationMode]::Local
$result =
    $session.SynchronizeDirectories($mode, $localPath, $remotePath, $False)
# Throw on any error
$result.Check()
if ($result.Downloads.Length -ge 0)
    Write-Host "Some files were downloaded"
else
    Write-Host "No files were downloaded"
