!& isn't retrieving remote files for Custom Command
Bill_Fields
Portland, OR
I've got the following custom command:
cmd.exe /c cd C:\Users\bfields\AppData\Local\Temp\!N!/ & start "" "C:\Program Files (x86)\Beyond Compare 4\BComp.exe" !& & timeout /t 6
When I capture the command with Ctrl+Shift, the results are as expected, but when I view the temp folder that WinSCP should be placing the remote files into, they're not there.
If I manually edit each file, they get downloaded to the temp folder I'm expecting them to be in, then if I execute the custom command again, then Beyond Compare opens the files like it should have in the first place.
I have "Local command" and "Use remote files" selected in the custom command configuration.
Why aren't the remote files indicated by !& retrieved before executing the remote command?
Bill
Re: !& isn't retrieving remote files for Custom Command
It's misunderstanding. The Use remote files means that the files won't be downloaded. It just makes WinSCP pass paths (or just names in case of !&) to the custom command. And it's up to the command to download the files on its own (if it needs the contents).
See https://winscp.net/eng/docs/ui_customcommand
You probably only need to uncheck the Use remote files to get what you need.
