Server Core issues
Server Core issues
First issue, I could not install WinSCP on Server core because the installer would not run.
2nd, I ended up downloading the .net & com library since all I'm doing is powershell anyway.
When I try to run it, I get this error:
Error: Exception calling "Open" with "1" argument(s): "The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail"
I think this is the same error I got when I was trying to run the installer as well. What is going on with this?
OS: Windows Server 2016 Server Core
bpr-guy
Followup
Here's what's being reported in the Event log:
Activation context generation failed for "C:\WinSCP\winscp.exe". Dependent Assembly Microsoft.Windows.Common-Controls,language="*",processorArchitecture="*",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.0.0" could not be found. Please use sxstrace.exe for detailed diagnosis.
Here's what's being reported in the SxS Trace:
Begin Activation Context Generation.
Input Parameter:
   Flags = 0
   ProcessorArchitecture = Wow32
   CultureFallBacks = en-US;en
   ManifestPath = C:\WinSCP\winscp.exe
   AssemblyDirectory = C:\WinSCP\
   Application Config File =
INFO: Parsing Manifest File C:\WinSCP\winscp.exe.
   INFO: Manifest Definition Identity is WinSCP,processorArchitecture="*",type="win32",version="5.0.0.0".
   INFO: Reference: Microsoft.Windows.Common-Controls,language="*",processorArchitecture="*",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.0.0"
INFO: Resolving reference Microsoft.Windows.Common-Controls,language="*",processorArchitecture="*",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.0.0".
   INFO: Resolving reference for ProcessorArchitecture WOW64.
      INFO: Resolving reference for culture en-US.
         INFO: Applying Binding Policy.
            INFO: No publisher policy found.
            INFO: No binding policy redirect found.
         INFO: Begin assembly probing.
            INFO: Did not find the assembly in WinSxS.
            INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_32\Microsoft.Windows.Common-Controls\6.0.0.0_en-US_6595b64144ccf1df\Microsoft.Windows.Common-Controls.DLL.
            INFO: Did not find manifest for culture en-US.
         INFO: End assembly probing.
      INFO: Resolving reference for culture en.
            INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_32\Microsoft.Windows.Common-Controls\6.0.0.0_en_6595b64144ccf1df\Microsoft.Windows.Common-Controls.DLL.
            INFO: Did not find manifest for culture en.
      INFO: Resolving reference for culture Neutral.
            INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_32\Microsoft.Windows.Common-Controls\6.0.0.0__6595b64144ccf1df\Microsoft.Windows.Common-Controls.DLL.
            INFO: Did not find manifest for culture Neutral.
   INFO: Resolving reference for ProcessorArchitecture x86.
            INFO: Attempt to probe manifest at C:\WinSCP\Microsoft.Windows.Common-Controls.DLL.
            INFO: Attempt to probe manifest at C:\WinSCP\Microsoft.Windows.Common-Controls.MANIFEST.
            INFO: Attempt to probe manifest at C:\WinSCP\Microsoft.Windows.Common-Controls\Microsoft.Windows.Common-Controls.DLL.
            INFO: Attempt to probe manifest at C:\WinSCP\Microsoft.Windows.Common-Controls\Microsoft.Windows.Common-Controls.MANIFEST.
   INFO: Resolving reference for ProcessorArchitecture MSIL.
            INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_MSIL\Microsoft.Windows.Common-Controls\6.0.0.0_en-US_6595b64144ccf1df\Microsoft.Windows.Common-Controls.DLL.
            INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_MSIL\Microsoft.Windows.Common-Controls\6.0.0.0_en_6595b64144ccf1df\Microsoft.Windows.Common-Controls.DLL.
            INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_MSIL\Microsoft.Windows.Common-Controls\6.0.0.0__6595b64144ccf1df\Microsoft.Windows.Common-Controls.DLL.
   INFO: Resolving reference for ProcessorArchitecture Data.
            INFO: Attempt to probe manifest at C:\Windows\assembly\GAC\Microsoft.Windows.Common-Controls\6.0.0.0_en-US_6595b64144ccf1df\Microsoft.Windows.Common-Controls.DLL.
            INFO: Attempt to probe manifest at C:\Windows\assembly\GAC\Microsoft.Windows.Common-Controls\6.0.0.0_en_6595b64144ccf1df\Microsoft.Windows.Common-Controls.DLL.
            INFO: Attempt to probe manifest at C:\Windows\assembly\GAC\Microsoft.Windows.Common-Controls\6.0.0.0__6595b64144ccf1df\Microsoft.Windows.Common-Controls.DLL.
   ERROR: Cannot resolve reference Microsoft.Windows.Common-Controls,language="*",processorArchitecture="*",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.0.0".
ERROR: Activation Context generation failed.
End Activation Context Generation.
Re: Server Core issues
I do not have any problems running installer or using .NET assembly on Windows 2016 without desktop (aka "core").
How do you get the "SxS Trace"?
