Removing .fiepart
pnadal@techcu.com
Removing .fiepart
Good Afternoon,
I would like to know how to remove the .filepart when transmitting a data. I have my "Enable transfer resume/transfer to temporary filename for" as disabled. I did tried researching the issue on the web, unfortunately, none of them has helped me. My job automation is failing because of the .filepart. If I transfer the file straight from WinSCP, the filepart doesn't show up.
Any help will do.
Thank you in advance.
