Error opening local file
jimson
I have getting a error which come randomly
Error opening local file c:\users\<user>\local\temp\ftp2.
C:Permission denied
I have check there no permission issue with the folder nor i am able to find the mention temp file.
Anyone know what going on?
Re: Error opening local file
jimson
Hi i have attached the logs however do note that we are not using the latest winscp version
jimson
That's not WinSCP log.
It looks like an output of Windows ftp.exe.
Hi martin,
Yes sorry to be confused with the winscp log. It seem that i did not enable the logging.
That the only log i have for now.
Then we cannot help you.
