Getting interim issues while using WinSCP version on windows server 2003 R2 Sp2
Vinay Shet
Hi All,
We are using WinSCP version 5.9.5.7441 on 3 of our servers.
On one server its working fine, but on other 2 servers we have issues.
Now after some successful runs for fetching and deleting the files from the remote sftp server. The jobs started failing with the below error
"WinSCP process terminated with exit code 3.
There was no output. Response log file C:\Documents and Settings\XXX\Local Settings\Temp\wscp15AC8.XXX.tmp was not created.
This could indicate lack of write permissions to the log folder or problems starting WinSCP itself"
the user we are using is an user which is the member of the administrator.
These issues are being interim and not being able to resolve this. Could you please help us on this.
System config is as below:
1. .Net framework 2.0
2. Windows server 2003 R2 Sp2
there are about 15 parallel sessions running on a single server with same user.
your help over this is much appreciated.
many thanks
Vinay Shet
Re: Getting interim issues while using WinSCP version on windows server 2003 R2 Sp2
What do you exactly mean by "interim"? Does the problem happen always or sometimes only? Does restarting the server help? Can you post a debug log file? (Session.DebugLogPath).
