ftp confusion
brandonm121
ftp confusion
below is a script i have that waork in windows native FTP but now WinSCP. How come?
put D:\SQL-diff\Intermodal\Intermodal_backup_2017_12_07_151400_9978544.bak
I've tried putting it in quotes, I've put the remote directory after it, I've been googling why it isnt working for the last hour.
Re: ftp confusion
There's no reason this should not work. Unless you use the command in a wrong context.
