Show us IpSwitch log file too.
Thanks for the response. I am using 5.9, but I upgraded to the latest version and got the same error. Here is the IpSwitch log. I connected in IpSwitch and navigated to one of the folders, so the log below is showing that.
Finding Host ftp.hpac-portal.com ...
Connecting to 107.23.205.124:990
Connected to 107.23.205.124:990 in 0.173500 seconds, Waiting for Server Response
Initializing SSL Session ...
220 FTP Server ready.
AUTH TLS
234 AUTH TLS successful
SSL session NOT set for reuse
SSL Session Started.
Host type (1): AUTO
USER ????
331 Password required for ?????
PASS (hidden)
230 User ???? logged in.
SYST
215 UNIX Type: L8
Host type (2): Unix (Standard)
PBSZ 0
200 PBSZ 0 successful
PROT P
200 Protection set to Private
Sending "FEAT" command to determine what features this server supports.
FEAT
211-Features:
MDTM
MFMT
TVFS
AUTH TLS
MFF modify;UNIX.group;UNIX.mode;
MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
PBSZ
PROT
REST STREAM
SIZE
211 End
Finished interpreting "FEAT" response.
Sending the FEAT command is optional. You can disable it in the site options of the profile.
PWD
257 "/" is the current directory
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (107,23,205,124,195,84).
connecting data channel to 107.23.205.124:195,84(50004)
data channel connected to 107.23.205.124:195,84(50004)
LIST
150 Opening ASCII mode data connection for file list
# transferred 260 bytes in 0.021 seconds, 98.780 kbps ( 12.347 kBps), transfer succeeded.
226 Transfer complete
CWD pre-processing
250 CWD command successful
PWD
257 "/pre-processing" is the current directory
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (107,23,205,124,195,107).
connecting data channel to 107.23.205.124:195,107(50027)
data channel connected to 107.23.205.124:195,107(50027)
LIST
# transferred 117 bytes in 0.007 seconds, 137.008 kbps ( 17.126 kBps), transfer succeeded.
QUIT
221 Goodbye.
Connection closed. Ready for next connection.
