using Get to pull a file from directory with a space in the name
waynehess
Blaine
A lot of the servers I connect to pull down files use folders with spaces in the name.
How do I get the WINSCP batch file to recognize those spaces to pull down the file
waynehess
Blaine
Re: using Get to pull a file from directory with a space in the name
Not sure, what you mean by "WinSCP batch file".
But this should help you:
https://winscp.net/eng/docs/scripting#quotes
https://winscp.net/eng/docs/commandline#syntax
This is what I mean by the batch file.
In the Get Line when the folder that I'm pulling from has a space in it. All the examples I've seen on the forum have no spaces in the folder name
"option confirm off"^
"OPTION transfer binary"^
"GET \Hosted Export\transfinderTo_ICExport.csv d:\transfinder\transfinderTo_ICExport.csv" ^
waynehess
Blaine
OK, so this link from the previous post gives you the answer:
    "GET ""\Hosted Export\transfinderTo_ICExport.csv"" d:\transfinder\transfinderTo_ICExport.csv" ^
Thanks, I had tried it with double quotes but apparently not double Double quotes.
