Scripted WinSCP fails with "File or folder 'Documents\My Music' does not exist"
jwatte
I'm trying to use WinSCP to automate copying my local files to a backed up directory on a UNIX server.
(That directory in turn is backed up as part of the regular server backups.)
I run WinSCP using task scheduler, once a day.
Unfortunately, whenever it runs, it dies in the middle of trying to copy Documents, because it's trying to copy a non-existent "Documents\My Music" directory. Here is the error message:
> 2017-12-26 08:59:07.497 Type: SSH_FXP_LSTAT, Size: 113, Number: 16623367
< 2017-12-26 08:59:07.498 Type: SSH_FXP_ATTRS, Size: 37, Number: 16623367
. 2017-12-26 08:59:07.498 File: 'Documents\My Music' [2017-12-07T18:44:37.158Z] [0]
* 2017-12-26 08:59:07.499 (EDirectoryNotFoundException) The drive cannot be found
. 2017-12-26 08:59:07.499 Asking user:
. 2017-12-26 08:59:07.500 File or folder 'Documents\My Music' does not exist. ("The drive cannot be found")
< 2017-12-26 08:59:07.500 Script: File or folder 'Documents\My Music' does not exist.
< 2017-12-26 08:59:07.500 Script: The drive cannot be found
* 2017-12-26 08:59:07.500 (EScpSkipFile) File or folder 'Documents\My Music' does not exist.
* 2017-12-26 08:59:07.500 The drive cannot be found
. 2017-12-26 08:59:07.500 Copying finished: Transferred: 187,944, Elapsed: 0:00:00, CPS: 663,269/s
. 2017-12-26 08:59:07.500 Script: Failed
. 2017-12-26 08:59:07.500 Script: Exit code: 1
. 2017-12-26 08:59:07.500 Closing connection.
This directory doesn't exist in my Documents folder, so I imagine this is some Windows-specific special folder that WinSCP somehow picks up.
Is there some way to get WinSCP to ignore that this "folder" doesn't exist, and continue copying?
Or some way to explicitly exclude this particular folder?
Here is my backup script:
C:\Users\jwatte>type winscp-backup.txt
open sftp://xxxxxx/ -hostkey="ecdsa-sha2-nistp256 256 xxxxxxx"
lcd C:\Users\jwatte
cd /var/fileserver/backup/xxxxxx
put -neweronly code
put -neweronly Desktop
put -neweronly Documents
put -neweronly AppData
# Execute the script using a command like:
# "C:\Program Files (x86)\WinSCP\WinSCP.exe" /log="C:\writable\path\to\log\WinSCP.log" /ini=nul /script="C:\path\to\script\script.txt"
Charles R.
I have the same problem
I have the exact same problem. Not only is this an issue with "My Music", but with a bunch of others such as "My Pictures", "Application Data", and so on. This is on an up to date Windows 10 machine.
Interestingly, although there is no folder marked "Application Data" on the windows machine, if I try to create one, Windows complains that one already exists. So there is something about the way Windows 10 is treating some hard-coded Folder names that is confusing WinSCP.
Also, for some reason I am having trouble getting WinSCP to exclude some of these names.
Re: I have the same problem
Your another post:
https://winscp.net/forum/viewtopic.php?t=25917
