Error 28: the file is corrupt
DavidDio
Mexico
Can you help me with this problem?
I get this result when the file is uploading. Also, the files updated can't be overwritted and the files have 0Mb size.
I share the log trying upload some files in TXT.
. 2017-12-26 12:41:38.833 Copying 1 files/directories to remote directory "/Import/" - total size: 74,798
. 2017-12-26 12:41:38.833 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2017-12-26 12:41:38.833 TM: M; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: ; ResumeL: 0
. 2017-12-26 12:41:38.833 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2017-12-26 12:41:38.833 File: 'C:\ATEB\Infile\Copia_Original\0340087589-20171222-204319.txt' [2017-12-22T19:44:06.866Z] [74798]
. 2017-12-26 12:41:38.833 Copying "C:\ATEB\Infile\Copia_Original\0340087589-20171222-204319.txt" to remote directory started.
. 2017-12-26 12:41:38.833 Ascii transfer mode selected.
. 2017-12-26 12:41:38.833 Opening remote file.
> 2017-12-26 12:41:38.833 Type: SSH_FXP_OPEN, Size: 68, Number: 4867
< 2017-12-26 12:41:38.833 Type: SSH_FXP_STATUS, Size: 47, Number: 4364
. 2017-12-26 12:41:38.833 Discarding reserved response
< 2017-12-26 12:41:38.833 Type: SSH_FXP_STATUS, Size: 56, Number: 4612
< 2017-12-26 12:41:46.913 Type: SSH_FXP_STATUS, Size: 43, Number: 4867
< 2017-12-26 12:41:46.913 Status code: 11, Message: 4867, Server: The file already exists., Language: en
. 2017-12-26 12:41:46.913 Cannot create new file "/Import/0340087589-20171222-204319.txt", checking if it exists already
> 2017-12-26 12:41:46.913 Type: SSH_FXP_LSTAT, Size: 51, Number: 5127
< 2017-12-26 12:41:46.991 Type: SSH_FXP_ATTRS, Size: 120, Number: 5127
. 2017-12-26 12:41:46.991 Asking user:
. 2017-12-26 12:41:46.991 **Overwrite remote file '0340087589-20171222-204319.txt'?**
. 2017-12-26 12:41:46.991 Destination directory already contains file '0340087589-20171222-204319.txt'.
. 2017-12-26 12:41:46.991 Choose, if you want to overwrite the file or skip this transfer and keep existing file.
. 2017-12-26 12:41:46.991 New: 74,798 bytes, 22/12/2017 01:44:06 p. m.
. 2017-12-26 12:41:46.991 Existing: 0 bytes, 26/12/2017 12:41:03 p. m. ()
> 2017-12-26 12:41:48.460 Type: SSH_FXP_OPEN, Size: 68, Number: 5379
< 2017-12-26 12:41:48.538 Type: SSH_FXP_STATUS, Size: 39, Number: 5379
< 2017-12-26 12:41:48.538 Status code: 28, Message: 5379, Server: The file is corrupt., Language: en
* 2017-12-26 12:41:48.538 (ETerminal) The file is corrupt; an filesystem integrity check should be run.
* 2017-12-26 12:41:48.538 Error code: 28
* 2017-12-26 12:41:48.538 Error message from server (en): The file is corrupt.
. 2017-12-26 12:41:48.538 Asking user:
. 2017-12-26 12:41:48.538 Cannot overwrite remote file '/Import/0340087589-20171222-204319.txt'.$$
. 2017-12-26 12:41:48.538 Press 'Delete' to delete the file and create new one instead of overwriting it.$$ ("The file is corrupt; an filesystem integrity check should be run.
. 2017-12-26 12:41:48.538 Error code: 28
. 2017-12-26 12:41:48.538 Error message from server (en): The file is corrupt.")
. 2017-12-26 12:41:49.398 Deleting file "/Import/0340087589-20171222-204319.txt".
> 2017-12-26 12:41:49.398 Type: SSH_FXP_REMOVE, Size: 47, Number: 5645
< 2017-12-26 12:41:49.476 Type: SSH_FXP_STATUS, Size: 56, Number: 5645
< 2017-12-26 12:41:49.476 Status code: 0
> 2017-12-26 12:41:49.476 Type: SSH_FXP_OPEN, Size: 68, Number: 5891
< 2017-12-26 12:41:49.538 Type: SSH_FXP_STATUS, Size: 39, Number: 5891
< 2017-12-26 12:41:49.538 Status code: 28, Message: 5891, Server: The file is corrupt., Language: en
* 2017-12-26 12:41:49.538 (ETerminal) The file is corrupt; an filesystem integrity check should be run.
* 2017-12-26 12:41:49.538 Error code: 28
* 2017-12-26 12:41:49.538 Error message from server (en): The file is corrupt.
. 2017-12-26 12:41:49.538 Asking user:
. 2017-12-26 12:41:49.538 Cannot overwrite remote file '/Import/0340087589-20171222-204319.txt'.$$
. 2017-12-26 12:41:49.538 Press 'Delete' to delete the file and create new one instead of overwriting it.$$ ("The file is corrupt; an filesystem integrity check should be run.
. 2017-12-26 12:41:49.538 Error code: 28
. 2017-12-26 12:41:49.538 Error message from server (en): The file is corrupt.")
* 2017-12-26 12:41:51.132 (EScpSkipFile) Cannot overwrite remote file '/Import/0340087589-20171222-204319.txt'.$$
* 2017-12-26 12:41:51.132 Press 'Delete' to delete the file and create new one instead of overwriting it.$$
* 2017-12-26 12:41:51.132 The file is corrupt; an filesystem integrity check should be run.
* 2017-12-26 12:41:51.132 Error code: 28
* 2017-12-26 12:41:51.132 Error message from server (en): The file is corrupt.
. 2017-12-26 12:41:51.132 Copying finished: Transferred: 0, Elapsed: 0:00:12, CPS: 0/s
. 2017-12-26 12:41:51.132 Listing directory "/Import".
> 2017-12-26 12:41:51.132 Type: SSH_FXP_OPENDIR, Size: 16, Number: 6155
< 2017-12-26 12:41:51.211 Type: SSH_FXP_HANDLE, Size: 11, Number: 6155
> 2017-12-26 12:41:51.211 Type: SSH_FXP_READDIR, Size: 11, Number: 6412
< 2017-12-26 12:41:51.289 Type: SSH_FXP_NAME, Size: 3225, Number: 6412
> 2017-12-26 12:41:51.289 Type: SSH_FXP_READDIR, Size: 11, Number: 6668
> 2017-12-26 12:41:51.289 Type: SSH_FXP_CLOSE, Size: 11, Number: 6916
. 2017-12-26 12:41:51.289 ..;D;0;1899-12-30T06:00:00.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087589-20171222-204319.txt;-;0;2017-12-26T18:41:03.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087590-20171222-215916.txt;-;75300;2017-12-22T21:00:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087591-20171222-215919.txt;-;74798;2017-12-22T21:00:09.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087592-20171222-220523.txt;-;74296;2017-12-22T21:06:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087593-20171222-221140.txt;-;74798;2017-12-22T21:12:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087594-20171222-221402.txt;-;74798;2017-12-22T21:15:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087595-20171222-222349.txt;-;75802;2017-12-22T21:24:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087596-20171222-224316.txt;-;81826;2017-12-22T21:44:07.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087597-20171222-225850.txt;-;82830;2017-12-22T21:59:07.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087598-20171222-230906.txt;-;74798;2017-12-22T22:10:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087599-20171222-230909.txt;-;74798;2017-12-22T22:10:09.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087600-20171222-231314.txt;-;80822;2017-12-22T22:14:07.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087601-20171222-231317.txt;-;80822;2017-12-22T22:14:10.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087602-20171222-231320.txt;-;76806;2017-12-22T22:14:12.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087603-20171222-231322.txt;-;79818;2017-12-22T22:14:15.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087604-20171222-231903.txt;-;77810;2017-12-22T22:20:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087605-20171222-232131.txt;-;83332;2017-12-22T22:22:07.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087606-20171222-232134.txt;-;74798;2017-12-22T22:22:09.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087607-20171222-232229.txt;-;75300;2017-12-22T22:23:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087608-20171222-234249.txt;-;0;2017-12-26T16:53:47.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087609-20171222-234604.txt;-;78814;2017-12-22T22:47:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087610-20171222-234623.txt;-;85340;2017-12-22T22:47:09.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087611-20171222-234911.txt;-;91364;2017-12-22T22:50:07.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087612-20171222-235156.txt;-;74798;2017-12-22T22:52:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087613-20171222-235324.txt;-;74798;2017-12-22T22:54:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087614-20171222-235327.txt;-;74798;2017-12-22T22:54:09.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087615-20171222-235407.txt;-;76304;2017-12-22T22:55:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087616-20171222-235914.txt;-;74798;2017-12-22T23:00:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087617-20171222-235918.txt;-;77308;2017-12-22T23:00:09.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087618-20171223-000632.txt;-;81324;2017-12-22T23:07:07.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087619-20171223-001026.txt;-;78312;2017-12-22T23:11:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087620-20171223-001253.txt;-;89858;2017-12-22T23:13:07.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 0340087621-20171223-001515.txt;-;74798;2017-12-22T23:16:06.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 Error;D;0;2017-12-25T00:35:22.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 Ok;D;0;2017-12-22T16:56:02.000Z;3;"" [0];"" [0];---------;0
. 2017-12-26 12:41:51.289 XML;D;0;2017-12-22T23:20:57.000Z;3;"" [0];"" [0];---------;0
Re: Error 28: the file is corrupt
It looks like a file system on the server is corrupted. Nothing you can fix on WinSCP side or over WinSCP. Contact your server administrator.
