Too many parameters for command 'open'
d.gerrardboards
UK
Good Afternoon,
Can anyone offer advice on the below? Spent days and can't figure it out.
Everything seemed to work before I specified the hostkey, now I can successfully run the connection part of the script, but not rm onwards.
winscp.com /command "open sftp://bla@bla.com/ -hostkey="C:\bla\sqlbackup\HOST.ppk" -privatekey="C:\bla\sqlbackup\SFTP.ppk" "rm TEST.TXT" "put C:\bla\sqlbackup\TEST.TXT" exit
Re: Too many parameters for command 'open'
If you need to use double quotes around switch value, you have to double them. See
https://winscp.net/eng/docs/commandline#syntax
Also, the value of -hostkey is a fingerprint not a path to a file.
https://winscp.net/eng/docs/scriptcommand_open#hostkey
winscp.com /command "open sftp://bla@bla.com/ -hostkey=""ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx..."" -privatekey=""C:\bla\sqlbackup\SFTP.ppk""" "rm TEST.TXT" "put C:\bla\sqlbackup\TEST.TXT" exit
The easiest is to configure the session in WinSCP GUI and have it generate the command-line for you: https://winscp.net/eng/docs/guide_automation#generating
