Having exception when GiveUpSecurityAndAcceptAnySshHostKey is enabled
Hello All,
I work with WinSCP in a closed enterprise network, so forcing users to enter fingerprints is a waste of time.
So I set GiveUpSecurityAndAcceptAnySshHostKey = true and when I try to connect, it throws an exception:
Setting FtpSecure = WinSCP.FtpSecure.Explicit, Implicit or None would not help, it still throws, same for WebdavSecure.
How can I bypass this issue?
Thank you.
System.ArgumentException:
'SessionOptions.TlsHostCertificateFingerprint or SessionOptions.GiveUpSecurityAndAcceptAnyTlsHostCertificate is set,
but neither SessionOptions.FtpSecure nor SessionOptions.WebdavSecure is enabled.'
Thank you.
